frame repair & ...
[Closed] frame repair & respray
[#618831]
Anyone know where I can get a bottle cage insert replaced & cheap respray done? Pref near to High Wycombe/Oxford/West London/Reading/Newbury area. Thanks
Posted : 09/06/2009 5:38 pm
no such thing as cheep unfortunately 🙁
I'm doing a DIY job at the moment and its costing a fortune in stuff!
£6 nitromors
£7 x 3 for hammerite rust treatemnt, primer and topcoat
£2 white spirit
£4 brush
£5 gloves
£3 glass paper
+ lots of effort
Next time its off to argos!
Posted : 09/06/2009 5:50 pm
I think I've found a srayer on a local ind estate, but I need to get the bottle cage insert replaced first - any ideas anyone?
Posted : 09/06/2009 5:54 pm
http://www.argoscycles.com/www/renovation-pricelist.htm
In Brissle tho.
Posted : 09/06/2009 5:55 pm
Hmm Argos want £110 for painting frame only! Looks like the bottle cage repair is going to be cheap though, still nothing more local to the chiltern hills?
Posted : 09/06/2009 6:05 pm
try API,mine went via shop(The bike shop on pinner road,north harrow)
Posted : 09/06/2009 6:10 pm
API bikes look more like it & only in Chelmsford, I'll give them a ring in the morning thanks.
Posted : 09/06/2009 6:22 pm
i think Vernon Barker (Sheffield) wanted about £6 to re do a bottle mount, i was then going to take it for a respray some where else much, much cheaper. clearly being in Sheff is no use to you but it should give you a good idea of cost.
Posted : 09/06/2009 6:23 pm
But it's worth it.
I had my Inbred repaired and sprayed by them, in the 2-pack epoxy. It's virtuallly undestructable. I dropped a spaeer on the TT and it bounced off without leaving a mark. A year later, it still looks like new.
Posted : 09/06/2009 6:40 pm
Sadly my frame is only worth about 2p & I just wanted to tart it up to match the forks I'd just bought, £6 bottle cage mount repair plus local respray looks like the route for me. Thanks
Posted : 09/06/2009 7:03 pm
dickyboy
any joy with the respray? if so where did you get it done?
Posted : 07/02/2011 4:36 pm
powdercoat is much cheaper for getting a frame done, not as nice as a good enamel but if it's not for a posh bike it's this hsould not matter. Should be able to find somewhere for about £40-60 ish.
RE: frame repair, there are lots of small frame builders all over the place who would do little jobs like this. I would ask at your local proper bike shop (i.e. old man with encyclopaedic knowledge of campag group-sets, central member of local club e.t.c) he / she will no doubt know someone who does simple frame repairs locally.
Alternately I've read that some mapp gas and a boss from ceeway would work. Never tried though only over used mapp on copper fittings for plumbing.
Posted : 07/02/2011 4:47 pm
Steel or aluminium frame?
There is a thing called a Rivnut that can be used; which is effectively a blindrivet /poprivet type of insert that can be fitted into the hole in the frame and already has an M5x0.8mm thread.
eg page 51
DV-17305
although not very commonly used it can be fitted to steel/ aluminium etc frames
Posted : 08/02/2011 1:24 pm
