Fox worn anodising/...
[Closed] Fox worn anodising/Stanchions question.
[#1410990]
The anodising on the lower left leg of my 2008 Fox Float 32 rl's has worn away back to the aluminium of the stanchion.
I know this is due to poor maintenance and to have the stanchions and bushes replaced im looking at around £250:00.
The question i would like to ask is that seeing as i cannot have the work done yet untill next month.
I have a new wiper/seal set ready to go albiet all too late, but would changing the oil now and replacing the seals make any significant difference to the performance of the Forks before i send them off for a proper rebuild ?
thanks
Paul
Posted : 14/03/2010 6:32 pm
 mrmo
i have a set of trashed rebas, similar state. after an oil change they do feel better. I guess it depends on how bad, but i would have thought it would help a little.
Posted : 14/03/2010 6:36 pm
Just to say I have a pair of marzocchi mx comp from 2005 and have had no probs. 120mm travel eta and have been through a lot and going strong. no maintance. can go for ages without anything going wrong. On 2nd pair since 1997
Posted : 14/03/2010 6:40 pm
yes, but marzocchi mx comps are crap forks, so whats your point exactly, and what has it to do with someone asking advice on fox forks?
Posted : 14/03/2010 9:29 pm
when are they. i have had them for 12 years. had fox and rockshox. both crap
Posted : 14/03/2010 9:38 pm
Hi, if you are going to send them away next month, assuming they do still work at the moment, keep the new wiper/seal set, and fit when they next need serviced.
My mate says the left leg wears, because of the disc brake pulling that stanchion every time you brake.
Posted : 14/03/2010 9:58 pm
