Fox Triad propedal ...
[Closed] Fox Triad propedal lever just spinning
[#3908034]
Hi guys
I have a Fox Triad 2006 rear shock and the blue lockout/pro-pedal/full open lever spins around completely loose without any click position feel at all
It is in the fully open mode at the moment and I'm riding it without problems but how much would it cost to fix the lever do you reckon?
I have emailed Fox and TF but still no reply yet
Will it cause damage if I don't get it repaired?
Is it possible to do myself with instructions?
Many questions to answer thank you
Is their an exploded parts diagram anyone have, I only ask after searching loads on the net
Best regards
Posted : 24/04/2012 6:22 pm
Try mojo http://www.mojo.co.uk/mtb.html you can access manuals through their site, try google " fox triad spinning " for more stories. When it happened to my shock, i tried to fix it, but had to send to mojo for a service,about £100.
Posted : 24/04/2012 9:08 pm
 LoCo
Sounds like the shock has lost gas pressure which puts pressure against the lever.
It'll will probably need a full service to rectify the problem.
Posted : 24/04/2012 9:26 pm
Or the grub screw holding the lever on is loose.
Posted : 25/04/2012 8:15 pm
 LoCo
unlikey Baz it would have just fallen off if it was 😉
Posted : 25/04/2012 9:00 pm
