Fox Talas Set-up
[Closed] Fox Talas Set-up
[#1051944]
Quick question:
Do I need to set the sag up correctly, or can I be lazy and just pump the correct psi load into the forks for my weight without going through the whole zip tie 25mm sag malarky?! 🙄
Posted : 18/11/2009 2:55 pm
It's only really a ballpark figure anyway, everybody has different requirements and you will need to fine tune the setting to produce the required results.
Posted : 18/11/2009 4:17 pm
 br
and what might the 'correct' psi be?
Posted : 18/11/2009 4:19 pm
What size Talas do you have?
Posted : 18/11/2009 4:20 pm
