FOX TALAS FORKS HEL...
[Closed] FOX TALAS FORKS HELP ADVICE
[#5391529]
Hi all, I am after some serious advice on Forks, I ride a Specialized Stumpy which currently has Fox 120RL forks on, they are great but have decided that I want some Fox Talas forks as you can adjust them on the fly. I tend do do a mixture of riding from cross country singletrack semi downhill (nothing epic) from Afan, Mountain Mayhem, Forest of dean sort of thing. I would appreciate any advice or even your views.
Thanks TWEEDVIPER
Posted : 04/08/2013 5:13 pm
 Euro
My advice would be to not bother with talas. Firstly they are expensive and secondly they wont be as good as the forks you're replacing.
I've a set of Talas but hardly ever use the adjustment on them. If I were to replace them i'd be giving [url= http://www.wiggle.co.uk/x-fusion-velvet-rl2-dla-tapered-suspension-fork/ ]these[/url] a go.
110-140mm travel for under £400
[img] ?w=350&h=350&a=7[/img]
Posted : 04/08/2013 6:40 pm
Had the Talas now removed the talas part and made them into floats. Never used the reduction system and the floats perform so so much better.
Posted : 04/08/2013 7:07 pm
I run 160 and 180 mm 36 Talas, like the height adjustment and stiffness a great versatile fork, bit stiff on the smaller stuff at the higher pressures I need to run and non sale items are very expensive, but love them.
Also just got the Velvets for a HT and I am super impressed for the price, work great out of the box, very supple, reasonable stiffness for a 32mm fork and I like that the travel adjustment alters the height when the lever is moved (on the talas a bounce of the forks are required).
For a FS frame I would probably look at the 34 mm Slant.
Posted : 04/08/2013 7:22 pm
