£35 for the RS version from CRC.
[i]I still don't get why people think forks should be fit and forget? They are usually the single most expensive piece of kit on your bike so should be treated accordingly. Follow the instructions for smooth feeling forks.[/i]
coz my 2006 marzocchis are fit and forget and from the sound of it the newer rockshocks too
my foxes are lovely light smooth and stiff but they take lot more looking after
im just gonna keep riding them till they die
"Had this after 4 months with my Fox Forks
Mojo will say as above have said-it'd then whether you can persuade them to show a bit of discretion
Have now bought fork oil and float fluid
Best way(IMO) is to take the lower legs off(every 15 hours or so)
Lets you inspect for any dirt ingress and clean/lubricate the foam rings
It's easier than trying to lift the seals(and to get them to reseat afterwards)
Not sure whether there have been design changes but stripped my lads 3 years old Fox Forks down at the weekend and the foam seals were still lubricated, no dirt and no stanchion wear-maybe some are just better than others
Talk to any LBS and they will all have stories to tell on Fox"
I stripped them down actually not you.....have slight wear on one of them. and one of the seals was fairly dry.
so cleaned them and lubed them
The rush to save weight on suspension forks has resulted in most of the companies reducing the volume of oil in their open bath systems.
Fox is 25ml? rockshocks is actually 16ml, I think manitou is 20-25ml too.
This is all well and good, but some of these forks are designed to use more oil than others in use - fox being the prime example. The reason they specify re-lubing every 15 hours is that hey expect the reserve of oil in the leg to be pretty much spent or contaminated.
In UK conditions, the oil gets used more quickly. More so if the foam rings aren't lubed by inversion, and we end up with lots of dry bushes and worn stanchions.
Inverting the fork with provide lube to the foam ring, allowing the seal to work effectively for longer, but depleting the oil quicker.
IMO, inverting the bike is a pre-requisite to ensure to seals function as they're meant to, and adding a bit more lube could extend the service interval too.
This principle works with Manitou's and Rockshox too.
AFAIR, Fox seals have only one integrated oil seal in the dirt wiper (Black ring) and sacrifice service interval for reduced stiction and improved compliance, Manitou have two integrated oil seals on their evil genius wipers (possibly three, since theres and internal garter spring too), whilst Rockshox shave at less two integrated seals and a further, designated oil seal.
IME, the number of seals directly corresponds to service interval requirements - Fox have always been needy, Manitou less so and Rockshox the least of all.
That said, last time I stripped my pikes they were a touch away from being dry and that was over 8 months.
inversion after every ride + cleaning the dust seal / stanchion interface will also help.
it's not the greatest idea to overfill TJ.... this will lead to an element of ramp up....i tried it and it's not the solution....the solution is to regularly keep them cleaned / serviced...
The vanillas I did this to are basically fubared anyway. I actually found the ramp up beneficial as I thought they blew thru their travel easily. I was concerned that they might blow seals from the extra pressures developed but it hasn't happened. If you want a bit more resistance at the bottom of the travel it might be worth trying but for sure its a bit of a bodge
I don't think one should attempt even the wiper cleaning procedure unless very confident, and that means not encouraging people to do it themselves. Here's why:
I'm generally OK with maintenance/repairs so after reading this thread, I thought I ought to do the wiper lube/clean procedure before my stanchions get scratched. So tonight I first tried the remove leg method which completely failed - as far as I can tell, I'm whacking an immovable nut/bolt and can't see how this "releases" the lowers so gave up after 30 minutes of whacking.
So I next tried the lever-up-wipers method - after 15 mins of levering with multiple tapings of my screwdriver, the air shock side wiper came up but in the process, I have marked the lowers quite a bit 🙁 There was little dirt and it was still oily. I tried the damping side and after 15 minutes of gentle wiggling it was still stuck. But then I slipped slightly and [b]the screwdriver has put a nice scratch in the stanchion[/b]
I am now extremely angry because I have borked my expensive forks while trying to implement a pointless maintenance procedure.
Buzz - you did loosen teh nuts before whacking them?
It is really simple to strip the fork like that. Dunno what you were doing wrong - loosen the nuts a turn or two and give 'em a thwack this breaks the interference fit between the damper rod and the lower- damper rod is then loose in the lowers. Remove nuts and pull the lowers off.
So really, as my 36's have slighly worn uppers, I could buy Enduro Seals, fit them and forget any worries? Would it be difficult?
"Buzz - you did loosen teh nuts before whacking them?"
yep
Whats actually wrong with having worn stantions?
Hairychested - MemberSo really, as my 36's have slighly worn uppers, I could buy Enduro Seals, fit them and forget any worries? Would it be difficult?
i have fitted enduro fork seals, it still happens
Bit late for buzz-lightyear now, but the [url= http://www.enduroforkseals.com/id28.html ]Enduro[/url] instructions give another method for loosening the nuts - there's a possibility they can rotate on the rod (and therefore not loosen), compressing the fork stops this. I used a couple of big zip ties.
I actually checked out 3 lots of intructions off the web before touching mine, for different tips, just to be sure I didn't miss anything. Seemed sensible, even though they were only £100 off ebay.
Also bought some touch-up paint in advance, in case I scratched the lowers.
My Vanillas's have exactly the same wear as MTBidle's, looks identical. Is this caused by dirt getting in the seals as well?. I must admit i would probably retire my set after the summer anyhow, 3 years of riding through all sorts of crap is probably the limit. though i must admit they do work luverly ........
before ****ting the nuts on the lowers, fully remove the nuts and save the crush washers for re-use !!!
then refit nuts a turn or two and give a good firm bashing 🙂
Fwiw all cartridge forks are prone to this problem. This week I've had 2 sets of rockshox into the workshop with bad stnchion wear. Not much fun on a £900 totem...
If you don't want to do the maintanence buy an open bath fork, simple really.
I'm going to ride the forks to the ground and then replace upper and lower legs with a full service. £400 but new forks. Or might sell them on ebay soon...
open bath fork
such as?
"before ****ting the nuts on the lowers, fully remove the nuts and save the crush washers for re-use !!!
then refit nuts a turn or two and give a good firm bashing"
Yep, did that.
BTW. Nail polish - will that heal my new scratch?
Good question is which forks are open bath? Why no upside down forks anymore. How about some upside down open bath coil forks for 2010?
best and most reliable forks were the old single crown Marz shivers.
I believe a 15 hr service interval is totally unrealistic
My chain needs lubing more frequently than that. Is that unreasonable too?
I was really sorry to see my old Z1 forks go. They were great. After nearly eight years of riding them, the stanchions were looking a little lighter near the seals than the rest of the stanchion. Hardly any wear at all.
I've been pondering something here. Now I run enduro seals on mine, there's a bit of space inside the foks between the oil seal and the dust seal. I was wondering what would happen if I drilled a little hole here and fitted a small grease neipple. I could then inject Manitou M-prep or similar which would purge any dirt from the wiper seal but he oil seal should keep it out of the internals.
Any thoughts?
onza - possibility of lubricating oil spilling through, esp when stored upside down.....
is that likely? I thought that the enduro seals actually 'sealed' so that shouldn't be a problem.
Buzz Lightyear - the scratch is unlikely to ruin your forks.
Were you holding the forks by the sliders when whacking the rod-ends?
If its not a common occurrence on other manufacturers forks- then I think you are very reasonable to request a free replacement. Its a defect/manufacturers design problem no? Fox would have to prove that other manufacturers suffer the same.
Am gutted for you Buzz, did you remove the nuts and washers, screw the nuts back on then use a rubber mallet as suggested? The first time I did the recommended service I convinced myself that the lowers were welded to the bolts and gave em a good few whacks before they finally gave way. I think in the end I needed to yank the lowers whilst standing on the bars (bike upside down). The same process seems easier now than the first time around
can someone send me a linky to the the Fox method of removing the lowers please.
Where do people get the oil for the forks?
Hora - fox will say its not a problem if the servicing schedule is followed correctly - and it probably isn't. thus no claim of unfit for purpose could be made
salad_dodger - MemberSo you automatically void the Fox warranty if you use them in a 24 hour race?!
Posted 3 months ago # Report-Post
richc - MemberNo, you just need to stop mid race for a service
Class. So they are really tightening up their service schedule to cover themselves for a brilliant/yet fragile product?
Is using Manitou Prep M greae a good or a bad idea? Why?
Am now well on the way to a third set of uppers! Will wear the ****ers out and go RS in future! Would not spend another penny on Fox's.
I have been METICULOUSLY FASTIDIOUS in following and exceeding Fox's guidance on maintainanice and still it happens. The seals just don't seal!
Is it any coincidence that Giant now spec RS SID's on their top of the line Anthems now?
I think though perhaps it is partly the british weather, but that makes the unfit for use, therefore sale, here.
Mate has just bought an 09 anthem 2 with RL100's, I warned him, so good luck to him. 2 months in, and wear has started, just visible on left leg as discussed in previous post.
Fox warrantied my first set after 8 months after pressure from my LBS, but bob hope after that. Perhaps we, as the Singletrack Massif, could all email "WatchDog" together? Who knows, could make for an interesting bit of filming. Does any one KNow If Nicky Campbell is an MTB'er??
This happened on my 2003 Vanillas. IMO it is a design fault in the design and material that the bushing is made of and how it is wrapped and pressed into the leg. In my forks the bushings simply were not flush.
Really the bushing should wear out and not the stanchion.
TandemJeremy - MemberThe issue is IMO that most fox forks have a cartridge damper and only 15 ml of oil in one side as a result. this is insufficient oil to splash lube the top bush on that side.
Inverting the bike after each ride allows this lube to get to the top bush.
I believe a 15 hr service interval is totally unrealistic and is put in the spec purely to prevent warrenty claims.
The older set of vanillas I got ( pre worn for pennies) I simply put 100 ml of oil in the non damper side. No alteration to function ( maybe a bit of ramp up from air compression in the dead space) and well lubricated top bush.
The only answers are to either follow the fox maintenance instructions closely, try over filling with oil as I have done, buy open bath forks which don't have this issue
This is My experience too. There is just not enough oil in the non damper side leg. If a seal on this leg starts to leak oil (even over just one long ride) there isnt enough oil left to in the leg to stop the bushing damaging the stanchion. So unless you stop riding as soon as you notice the leak and walk the rest of the way your going to damage your fork. Putting more than the recommended amount of oil ruins the action of the fork for me. If fox designed it to run more oil in the first place this would less of a problem. The single piece OEM Fox Fork seals are rubbish too! Best use a seal and a wiper, Enduro or Rock Shock seals are much better.
Has anyone heard this happen to Magura fork stanchions?
Wife wants an Orange 5 Pro but I'm starting to worry about the suitability of Fox forks to the UK environment and hence wonder if it's worth getting a bike where there is a known weakness in a main component.
No.
Get them swapped out at the shop.
