Fox skf seals - low...
[Closed] Fox skf seals - low friction issue
[#3874317]
I bought some low friction fork seals off loco a month back and I can't believe the difference in my forks. They feel awsome.. My float 32s are now great. Problem is I failed to seat the dust wipers fully fully flush, there is around half to one mm gap at approx 30% of the seal circumference. Is this going to cause me problems or is this normal.
I'd post an image if I knew how!
Posted : 15/04/2012 9:45 pm
Probably a good idea to get it seated properly, special tools exist but a large socket or similar can be used to press/tap it in fully(don't be tempted to press on it with the flat of a large screwdriver, one slip and you'll be buying another set).
Posted : 16/04/2012 7:16 am
