Shall be shortly replacing the dust seals on Fox forks (TALAS 32mm) with new low-friction SKF seals. Foam rings to be soaked in 50/50 mix of 10wt/float fluid (thanks Loco), just wondering if the dust seals should be lubed with the same, or greased with RSP Ultra Slick (or similar) - any experience? Cheers. (yes I know I should've asked Loco earlier but I forgot..!)
Posted : 10/01/2013 12:00 am
I lubed them with 10wt oil when i put them in. It says to do so in the fox tech-docs on their site.
Posted : 10/01/2013 12:14 am
As Enigmas said with me too
Posted : 10/01/2013 12:34 am
I lubed them, along with the foam rings, with Float fluid, as Mojo recommend.
Posted : 10/01/2013 12:35 am
I wouldn't use grease. It attracts muck and turns into grinding paste and you need new seals again.
Posted : 10/01/2013 1:54 am
