I want to put a remote lever for the rear shock on my canyon spectral al 8.0. Can anyone point me to the correct parts?
Possibly requires a full service and rebuild as it may replace the bits in the compression adjust. Consult mojo the fox importer for definitive advice though
Talk to Mojo.
Seriously though, do you really want a remote? I've always avoided any fork or shock with a remote.
I'm not 100% sure I want/need a remote lever, just I've come close to hitting some trees head on whilst looking down at the rear shock to try and change it from soft to firm setting!
The float x certainly has a remote lever conversion kit. I'd assume the float evol does also as its is available in both lever/remote formats.
I'm a believer in remotes, fork and shock
To convert the float evol to remote will be expensive, it needs new compression and rebound adjusters and a new eyelet.
What shock length is it?
This is what I want to do, I just can't find the parts for the rear shock.....
[url= http://www.ridefox.com/help.php?m=bike&id=524#ctdremoteinstallation(rearshockonly) ]Weblink[/url]
