....will I blow a limb off servicing it myself?
or will it just be impossible to remove the air sleeve?
Ta
Posted : 11/04/2009 10:13 pm
i think given the massive warnings i would admit defeat and send it off... not worh risking breaking it!
Posted : 11/04/2009 10:41 pm
mate its a 5min job that any numpty can do.
deflate and remove the shock and fitting kit put a rag through the eyelet (stops aircan flying off and hurting you). using a strap wrench undo the aircan <pop> replace/reuse the seals and do back up, pump up and your done.
£80 for this is throwing your money down the drain
Posted : 11/04/2009 11:34 pm
i stand corrected!! usseful to know¬!
Posted : 11/04/2009 11:38 pm
its a piece of piss.
let the air out then crack it open.
Posted : 11/04/2009 11:39 pm
