Fox RP23 service
[Closed] Fox RP23 service
[#8422622]
Finally got round to servicing my rear shock, however...
All the online videos tell me to remove a seal from around the white part in the picture, there was no seal in there. Question is, should there be a seal? There is one in the seal kit that would fit perfectly in there.
Cheers!!
Posted : 30/03/2017 11:03 am
There is an o-ring on the shaft, that holds a metal washer snug against the spacer and one on the shock eyelet piece, underneath the spacer.
The spacer itself doesn't need a seal, it just takes up air volume.
https://www.pinkbike.com/news/tech-tuesday-How-to-Install-a-Fox-Air-Volume-Spacer-2011.html
Posted : 30/03/2017 11:45 am
Have got the metal washer and o-ring, just moved them out the way for the picture. Thanks for the link!!
Posted : 30/03/2017 12:06 pm
