fox rp23 rear shock...
[Closed] fox rp23 rear shock pressures
[#653708]
my friend thinks his rear shocks abit broken...he is running it with 310 psi...what do you have in urs...its a 6 inch travel RM switch
Posted : 22/06/2009 8:35 pm
isn't the limit 300? i'm on a fox float r 2007 on a giant trance, run about 130psi.
FYI my dhx 5.0 air is about 160psi on a marin quake? i think?
Posted : 22/06/2009 10:00 pm
Doesn't it sort of depend how fat you are?
I would suggest that it's either broken, or you should get a coil shock.
Posted : 22/06/2009 10:54 pm
 ton
i ran mine at 300 psi, i am 21stone.
i have now dropped it to 270 psi and it rides a load better.
your mate must be mahoooooosive 😀
Posted : 22/06/2009 10:57 pm
