Fox RP23 Low Volume...
[Closed] Fox RP23 Low Volume on Meta 5.5
[#5098121]
I have recently been giving my long abused Meta a bit of TLC and found that the rear shock (plain old Float R) was in a bad way (vibrating and making bad noises when compressing). I was going to send it off to be serviced, but then spotted what I though looked like a bargain on CRC - a RP23 (Low Volume) for £179. I naively thought that as I would spend at least £100 on the Float R service, I may as well spend a bit more and get a better shock. Not being a full on bike geek, I didn't realise that shocks come with different tunings specific to bikes and riders. I'm guessing the shock will probably be a mid tune (it's yet to arrive, so I don't know yet) and am wondering if that will be OK for my Meta 5.5 and with a 12.5 stone rider doing mainly XC (but also a bit of Alpine downhill shortly!). I know that TFTuned do amazing things to shocks, but I'm not sure if I need to spend the money. Seems nobody has a high opinion of the boost valve system which appears prone to failure, and many people say the RP23 is a bit harsh. Should I just send it off to TF as soon as I get it and have it sorted, or just fit it an ride? Opinions please (but not about my naivety!).
Posted : 24/04/2013 12:49 pm
Sounds pretty much perfect. I found my Meta far too sort with a high volume shock, they're plush enough with a standard one.
It depends if you want the ProPedal on the RP23 really. Is your old Float R open valve or does it have some ProPedal? If it's the latter I'd definitely get the RP23 just for the open valve.
Posted : 24/04/2013 12:53 pm
Thanks! My float R is open valve - no ProPedal. So fit the RP23 and just ride it as it comes then?
Posted : 24/04/2013 12:59 pm
Why not just ride and see what you think? If it's awful, you can always get it tuned and at least you'll be starting off with a new shock from the off. And if you're happy with the way it rides, you can just use it as is. Seems logical?
Posted : 24/04/2013 1:05 pm
Thinks that's what I'll do - kind of wanted to make sure I hadn't done the wrong thing buying it. Cheers!
Posted : 24/04/2013 2:07 pm
