Anyone else running 200lbs in theirs? Noticed my bike was wallowing in its rear travel last nite, and inspired by the posting of a link to the fox online help centre, had to take my pressure from 140 lbs to 200lbs to get the correct sag!
Do you set it with Propedal on or off, mine sags more with it off. I set up the sag with propedal on, when I switch it off whilst riding it drops the back end a bit, which is nice for going downwards.
150 in mine btw and Im a larger lady.
Is it a high volume air can version?
Yes, on a Heckler.
Read this then.
[url= http://forums.mtbr.com/showthread.php?t=503070 ]High volume can modification[/url]
It has really improved mine, making it much more progressive throughout the stroke without having to keep adding more pressure.
Set with propedal off!
TBH I don't use the propedal function that much! Mebbe on the road to stiffen the back end up a bit! Have a Talas RLC on the front too, just find a setting I like and leave well alone! Still..... its nice to have the ability to faff!
What frame?
Marin Attack Trail Rage! .... and no I don't have a beard or smoke a pipe 😀
