Fox RP2 pro pedal p...
[Closed] Fox RP2 pro pedal problems
[#3874936]
OK guys
rescently replaced the seals and oil in my RP2 boost valve shock and since then the ProPedal doesn't seem to be working properly anyone got any ideas what could be causing this and any potential fixes
cheers
Dave
Posted : 16/04/2012 7:26 am
Sounds like the damper side of the shock not the air can side has something wroung with it so presuming you just did a air can services you could have not have changed how the propedal worked. Sounds like it needs a full strip down, you sure the propedal is not working what's it's tuning and the bike it can be pretty subtitle on some bike designs.
Posted : 16/04/2012 7:50 am
yeah just did an air can seal and fluid replacement, never had a problem before it seemed to loose some air hence the rebuild, but since refitting it there seems to be more bob when there was little before
Posted : 16/04/2012 5:42 pm
could it just need the rebound adjusted if you've just made the air-can more slippy? How long did it go between services?
Posted : 16/04/2012 5:45 pm
that was it's first service only had the bike 12 months and have only done a couple of hundred easy miles 😉
Posted : 16/04/2012 6:12 pm
