Trying to do an aircan service on this shock, but when i go to unscrew the aircan it just spins and spins. It has a high volume aircan and I believe the method for this is slightly different.
Can anyone give me a pointer, link to procedure? Thanks.
There are quite a lot of threads on there keep spinning and then pull down. It does airlock a bit and creates suction (you have let the air out ok?) try holding the valve open whilst pulling it off 🙂
Thanks for reply. I got it off now. The high volume bit has a circlip at the bottom, after removing this the high volume bit slides off leaving the main aircan which can now be unscrewed. Its only like this on the high volume version and almost none of the youtube vids show this bit.
