Fox RLC / RL identi...
[Closed] Fox RLC / RL identification
[#2739932]
Just bought a pair of forks of the bay. Seller had them listed as F100 RLC 2008 model
When I look at them I can only see a L (lockout) and R (rebound) adjust). I can't see a compression dial.
Am I missing something, can the C on early models by adjustable by air pressure at setup rather than via a lever?
It it helps there is a air valve at the top of the left stantion and a black hex bolt (with silver center at the bottom of each leg)..
Advice please??
Posted : 11/05/2011 10:54 am
[url= http://www.foxracingshox.com/fox_tech_center/owners_manuals/08/eng/FOXHelpEnglish.pdf ]http://www.foxracingshox.com/fox_tech_center/owners_manuals/08/eng/FOXHelpEnglish.pdf[/url]
Manual should help.
Posted : 11/05/2011 10:56 am
RLC's should have red rebound adjust (R), blue lockout lever (L) & blue compression adjust dial (C) on the top of the right hand leg.
Should also have lockout threshold adjuster on the bottom of the right hand leg.
Sorry to say, but from your description it sounds like you've been mis-sold some RL's...
Posted : 11/05/2011 11:31 am
