Fox lower leg servi...
Fox lower leg service torque
[#13148457]
Anyone know the torque for the bottom bolts under the lower legs? The 10mm nut with the plastic crush washer.
It's an aluminium nut on an aluminium thread so don't want to over tighten them. They wern't very tight when I removed them.
Thanks
Posted : 09/02/2024 4:45 pm
https://www.ridefox.com/fox17/help.php?m=bike&listall=service
Should have the info in there somewhere, maybe under seal replacement or any procedure that involves removing the lowers. What fork do you have?
Posted : 09/02/2024 5:08 pm
https://www.ridefox.com/fox_tech_center/owners_manuals/013/Content/Torque_Values.html
May be slightly old chart, but Bottom nut torque 5-6 n/m seems pretty standard and corresponds with my 'snug, not pissing oil out' guideline.
Posted : 09/02/2024 5:13 pm
^ I'd agree with that. 50 inch pounds / 5.65Nm appears to be pretty standard
Posted : 09/02/2024 5:22 pm
reeksy and reeksy reacted
34 Factory Step Cast
Posted : 09/02/2024 5:36 pm
50 in-lb / 5.7 NM (service procedure)
50+/-5 IN LBS (parts drawing)
From the fox website;
Posted : 09/02/2024 7:14 pm
Thanks. Torqued up to just over 5Nm now.
Posted : 09/02/2024 10:53 pm
