Fox Lower Leg Remov...
[Closed] Fox Lower Leg Removal
[#3836384]
I've done this before, but this time I can't get the lower leg removed. Best way to describe it is feels like theres some kind of vacuum has been created in the leg which is preventing removal
Any similar experiences?
ta
Posted : 03/04/2012 9:14 pm
Tap the threaded ends that protrude from the lower ends (with the nuts on loose so as not to damage threads) to break the seal so to speak, then pull. Simples.
Posted : 03/04/2012 9:40 pm
Thats what I usually do and have no problems.
This time round it feels like the fork still has air in it, despite removing it all first. Its like it has dropped down to about 5 cm of travel. When I tap the thread ends all that happens is the fork compresses, rather than knocking them loose.
Posted : 03/04/2012 9:52 pm
Can you stop the lowers moving as you tap the bolts? A second pair of hands helps.
Posted : 03/04/2012 10:00 pm
I've just tightened up all the nuts, and pumped them up to try again. All fine, then as soon as I depress the air valve the lower rides back up about 5 cm up the stanchion, even though there is no weight on the fork at all (its in a stand).
Can't remember this happening beofore..think its jiggered, which is a bit pish given I'm in the middle of training for a race 🙁
Posted : 03/04/2012 10:16 pm
Why are you letting the air out? Leave it under pressure and you have a more solid base to tap against. I prefer to put the bike upside down, and put my foot under the fork brace for support when I tap them.
Posted : 04/04/2012 7:04 am
Yeah, leave the air in.
Posted : 04/04/2012 11:11 am
[url= http://cute-n-tiny.com/wp-content/uploads/2010/05/3-legged-fox.jp g" target="_blank">http://cute-n-tiny.com/wp-content/uploads/2010/05/3-legged-fox.jp g"/> [/img][/url]
APF
Posted : 04/04/2012 11:40 am
@ alex.....Coffee on iPad now thanks....
Posted : 04/04/2012 11:42 am
And that was my 1st posted 'photo too. Glad to be of service 🙂
APF
Posted : 07/04/2012 11:13 am
