fox forks.....advic...
[Closed] fox forks.....advice
[#5237578]
stumpjumper 2008........forks...worn stancions, time to replace or get fixed ?
Posted : 11/06/2013 7:32 pm
Bin em and get some rcokshox
Posted : 11/06/2013 7:45 pm
Or get xfusion velvets for 2/3 the price of rockshox 🙂
Posted : 11/06/2013 8:23 pm
Are they leaking oil? Are the bushings loose? Its been asked on here before, and consensus was that you ride them till they die/leak horribly etc. I've some fox32 talas with a nasty scratch on, and a bit of wear on one leg. They work fine, new seals recently, hold air fine and don't leak oil. OK the seal may not last as long as a smooth pair, but they are £20 to replace, and takes 1/2hr to do every couple of months, not £400!
Posted : 11/06/2013 8:32 pm
Stanchion assembly "CSU" is about £160 seal kit £25 Bush kit £25 Oil and lube £10 labour 2 hours at £?????
Easy £250 to get them fixed.
Sell them on ebay as spares or repair for £50
Get some Rockshox Rebas from on-one for £279
http://www.on-one.co.uk/i/q/FORSREBRLT120/rockshox_reba_rlt_solo_air_120mm_fork
Posted : 11/06/2013 10:48 pm
