On Sunday when travelling fast they felt terrible, like a loose headset. I'm hoping a clean and a seal change will make them better. Where is best for seals and fork oil.
32 evolution open bath. Had them just over 12 months.
You're doing really well. Normally you have to service fox when they come out of the box, and then every time you look at them after that.
TF will do you a service kit for under £45, Mojo for £55 but with a bigger bottle of Float fluid (for more frequent minor wipe servicing).
You aren't really going to save much on ebay with less certainty of what will arrive.
If they're rocking like that though I'd be careful - might be a bigger problem if it is the fork that's doing it and not the headset, stem or a loose wheel - the bushings in the lowers on Fox 32's can give exactly this feeling if knackered - and they aren't really a DIY job.
