fox forks help?
[Closed] fox forks help?
[#3565047]
ive been offered a set of fox forks,
and all the info the person can give me is "fox shox 32 series 2 year 2007"
does anyone know what these are like, he doesnt have anyway of sending me a pic and its quite a long drive just to see what they look like.
so any iformation on these would be great
Posted : 14/01/2012 5:46 pm
be careful of buying forks of that age as they may have the stanchion wear.
If he can't provide pictures I would stay away
Posted : 14/01/2012 5:59 pm
They could be F-series, Floats or Talas'. R, RL or RLC? How much travel? What colour, this could help identify what type they are. If the stickers have been removed ask the seller what it says on all the adjusters.
What ever they turn out to be make sure the steerer length is long enough for your frame!
thanks for the replies
ive got no clue about forks, what does R, RL, RLC stand for
ill ask him what travel they are and what colour and post back
i think the guy seems genuine but he doesnt sound as if he knows much about bikes, as he has offered me a good few things for what i think is a good price.
Posted : 14/01/2012 6:11 pm
R means rebound, L means lock out and C means compression.ie there are dials to alter all of these things or not if the acronym is not there.
As already mentioned be wary of stanchion wear. Fox are notorious for premature wear. Note that you may not be able to see it either as quite often it is below the seals.
Posted : 14/01/2012 6:34 pm
Sounds dodgy to me! Good bits but seller doesn't know much about them, hmmm!
Anyway, what frame are they for? You need the fork travel to match the frame's recommendations.
The letters correspond with the forks external adjustments...R - Rebound. L - Lock-out. C - Compression.
Apart from the more letters meaning more adjustments, they would also cost more new. If they've got a lever on the left leg with two numbers on, that's a travel adjust...you only get that on the Talas.
Posted : 14/01/2012 6:36 pm
Cheers again for the replies, I'll post back when I find out more,
They are for my old giant xtc 3 frame year 2005 if that makes any difference?
Posted : 14/01/2012 7:15 pm
Update if it makes any difference they are black with 100mm travel
Any help appreciated
Posted : 14/01/2012 9:45 pm
If they are black they are probably the Fox vanillas which are coil spring forks rather than air spring. They worked fine just a bit heavier than the air sprung Floats plus you may need to budget a new spring depending on your weight. Still had the same stanchion wear problem mind.
Posted : 14/01/2012 11:14 pm
