Fox forks base nut ...
[Closed] Fox forks base nut thread size?
[#3665308]
Any of you guys know off the top of your heads what thread size on the base nuts on each leg?
For some reason M8 & M10 spring to mind?
Posted : 10/02/2012 9:23 pm
I think the head size is 8mm if that helps
Posted : 10/02/2012 9:34 pm
Thought it required a 10mm socket
Posted : 10/02/2012 10:00 pm
10mm
Posted : 10/02/2012 10:03 pm
Yes I know what size A/F the nut is, I want to know thread size?
Cheers 😉
Posted : 10/02/2012 10:34 pm
if you knew that - how do manage to think it could be m10?
Posted : 10/02/2012 11:00 pm
The 10mm A/F nuts on the bottom of Fox Forx are threaded M8
Posted : 10/02/2012 11:03 pm
It's 8mm fine thread, so I think that's 1mm pitch.
Posted : 11/02/2012 12:25 am
Jota180 - On forks with high and low speed compression the nut A/F size is bigger, hence why M10 was mentioned.
Also if you read the title of the post I ask for thread size, not the A/F size of the nut!
All others thank you for your comments!
Posted : 11/02/2012 6:23 pm
