Fox forks 140 > ...
[Closed] Fox forks 140 > 120?
[#3285445]
I know 120 > 100 can be done, can 140 > 120?
Ta,
R
Posted : 26/10/2011 9:47 pm
 gamo
I have a pair of 2011 floats which were set to 120mm and i have now changed to 140mm, just need to move the spacer on the rod.
Posted : 26/10/2011 9:54 pm
 gamo
So answer is yes! instructions on the Fox tech site.
Thanks gamo. I did have a look on the Fox website here...
[url= http://service.foxracingshox.com/consumers/index.htm ]QuickTech forks > Changing 32 mm FLOAT & F-Series Fork Travel[/url]
[i]"All 32 mm FLOAT and F-Series forks can be reduced to 80 mm travel by adding travel spacers. The only FLOAT or F-Series fork models that can be INCREASED in travel by removing travel spacers, for all model years, are the following:
F29 80 mm (can be extended to 100 mm maximum travel)
831 100 mm (can be extended to 120 mm maximum travel)"[/i]
So no mention of 140 > 120...is there a more up-to-date page that I've missed?
Cheers,
Posted : 27/10/2011 11:53 am
I've got a set of 2009 140mm Floats that I'm running at 120mm.
Posted : 27/10/2011 11:57 am
Heh...maybe I should read a bit more carefully!
[i]"The only FLOAT or F-Series fork models that can be [b]INCREASED[/b]"[/i]
So looks like I can derease OK. Anyone know what the 150 will space down to?
Posted : 27/10/2011 12:04 pm
140mm
Posted : 27/10/2011 12:10 pm
You should be able to space them down to 100mm and possibly lower.
I've done 36's down to about 110mm and I believe dirt jumpers/4x have ran them down to 80mm.
Posted : 27/10/2011 12:44 pm
