Fox Fork Service - ...
[Closed] Fox Fork Service - Oil volumes
[#4296857]
OK, I expect this has been done to death - if you remove the lower leg on say a 2009 TALAS 140 RLC Fork, should you put any suspension fluid in the bottom of the lower legs on reassembly? Foxs oil volume chart ( http://service.foxracingshox.com/consumers/Content/Service/oil_volumes.htm) states 10ml in the spring side oil bath, and 160ml in the damper side oil bath.
So does "oil bath" refer to the bottom of the lower legs? I would think not for the damper side, as 160ml aint going to fit in there. Their terminolgy is not clear to me.
And then you should apply Float Fluid to the "main chamber" and "negative chamber". To what does that refer?
Posted : 25/08/2012 5:39 pm
[url= http://www.mojo.co.uk/dustwiper.html ]Mojo[/url] Have you watched the Mojo video? If it's just a lower leg removal then it's 5ml suspension oil in the air side and 10ml suspesion oil in the TALAS side
Posted : 25/08/2012 6:25 pm
