Hi All,
I've had some Fox talas 32mm 140mm 08's for over a year. they have started to leak oil onto the left stanction, past the seal/dust wiper.
I have bought a seal kit & float liquid. I'm now thinking that I also need seals for the internal part where the push rod enters the stanction. Where do I but these/what are they called?
cheers everyone. 😉
If they are open bath forks then just change the seals you'll be fine. servicing the damper is a professional job really.
Thanks for that - does anyone know if my forks are open bath?
Fox Talas 140mm RL 2008 QR.
I really want to do this myself to avoid costs but I'm worried that it's too big a job if they're not open bath...
They will be open bath:
http://www.cyclistno1.co.uk/features/maintenance/fox-forks-wiper-seal-service.htm
http://www.foxracingshox.com/fox_tech_center/owners_manuals/08/eng/2008_om_eng.htm
http://www.foxracingshox.com/fox_tech_center/owners_manuals/08/eng/Content/Forks/32MM/TALAS_RLC.htm
great, thanks...
I've heard that if I replace the oil in the lower sections, I can use motor oil of different weights. Can anyone guide me to what may be best if I'm just under 12 stone & rag my bike proper... 😉
There are some really good instructions on [url= http://service.foxracingshox.com/consumers/index.htm ]this[/url] site. Helped me so much when I was servicing my Fox 32s.
Just ring Loco and buy the oil and seals off him. He'll see you right.
The easiest is to follow the fox instructions I linked to:
For weights just need 7 Wt and 10 wt (damper side) decent fork oil from online or in motor store and either gearbox oil or float fluid for the seals 🙂
http://www.foxracingshox.com/fox_tech_center/owners_manuals/08/eng/Content/Oil_Volumes.htm
Workshop closed until 26th Sept
[url= http://service.foxracingshox.com/consumers/Content/Service/QuickTech/32_Talas_ll_seal_change.htm ]just follow this it's a doddle[/url]
