Fox fork broken - a...
[Closed] Fox fork broken - any ideas?
[#5331313]
Happily rolling along on a bridleway, and suddenly I hear a loud twang. I first thought I had broken a spoke, but then I saw that my 120mm travel Fox Float R had much more stanchion exposed than normal (like 140mm or so), and topped out violently when I tried to compress/release it - no damping at all. This was only my second ride after a (very) expensive fork service... I am going on a biking holiday later this week, so no time to send it back to the service people. What could this be? Something I could try to fix myself? Thanks!
Posted : 14/07/2013 12:41 pm
Something snapped on the damping cartridge, could be the fixing nut at the bottom or the shaft. I very much doubt it'll be a self Give the service place a call and ask them what they can do to help.
Posted : 14/07/2013 12:56 pm
Turn the forks upside down and check that the nuts are still there on both side of the fork
Posted : 14/07/2013 1:13 pm
Otherwise I doubt If you didnt want to do the service that you'll be able to remedy what ever has broken
The nuts are both there. I'll take the fork off the bike and see if they are loose or something.
Posted : 14/07/2013 1:19 pm
Speak to the service people they might be able to turn it around quickly.
Posted : 14/07/2013 1:25 pm
Yeah I'd ring them up and tell them you had the forks serviced before you were going away and see if they can sort them out on a quick turnaround, clearly somethings not quite right with them
Posted : 14/07/2013 1:34 pm
Who did the servicing? And definitely don't take the forks apart yourself *until* you've spoken to them, you would easily invalidate your warranty with them.
Posted : 14/07/2013 1:56 pm
Good advice - I won't touch them and speak to Mojo first. I'll let you know what happens...
Posted : 14/07/2013 1:59 pm
Update: Very impressed with Mojo. They have fixed them under warranty and will ship via courier so I should have them back just in time. Terrific - superb customer service!
Posted : 18/07/2013 4:44 pm
Great to hear a good news story amongst the lbs/supplier/manufacturer woes!
Posted : 18/07/2013 5:07 pm
They arrived this morning, with Kashima coating thrown in for free. Mojo have my business forever and always. 😀
Posted : 19/07/2013 3:54 pm
