Fox flux sizing Que...
[Closed] Fox flux sizing Question
[#3957299]
I am a medium in a giro helmet - 59cm head
what size flux do you have and what size is your head?
Posted : 09/05/2012 10:19 am
62cm (yes 62cm) and a L/XL
Posted : 09/05/2012 10:21 am
which end of the scale are you on teh adjustment?
Posted : 09/05/2012 10:30 am
to be honest there's still adjustment left 😯
Posted : 09/05/2012 10:33 am
62cm and a L/XL Flux is a good fit still some adjustment left. 661 Recon is virtually the same helmet.
L/XL Giro Xen/Xar/Feature also very good fit (for me)
L/XL Urge way too small.
Posted : 09/05/2012 10:35 am
7 3/8" (in us hat size) and from memory a medium flux (I'll check when i get home) on one of the tighter settings on the clip.
Posted : 09/05/2012 10:46 am
my size is 58.5 cm and my fox flux is a s/m, I,m approx halfway on the adjuster
Posted : 09/05/2012 10:58 am
right s/m sounds fine then - how much adjustment is left?
Posted : 09/05/2012 11:18 am
Just check on the largest setting I can fit three fingers at the back which I did a quick measurement and it looks around 60/60.5
Posted : 09/05/2012 5:38 pm
I had a medium Giro Hex, got a S/M Flux- perfect.
Posted : 09/05/2012 5:41 pm
Sorry mine is a L/XL and head size is 59cm - clasp at back is on the tightest setting.
Posted : 09/05/2012 7:14 pm
58cm and s/m on flux and stryker (which is betterer)
Posted : 09/05/2012 7:18 pm
58cm and a S/M Flux. Plenty of adjustment both ways.
Posted : 09/05/2012 7:21 pm
I am size 59cm also. I tried both s/m and l/xl. I bought a l/xl after lots of swapping between the 2. Could have got away with the s/m but there wasn't much/any adjustment left. L/xl is pretty much on its tightest setting but gives room for when my hair is a bit more bouffant or to wear a hat underneath in the winter. I would have felt too restricted and hot in the s/m on hot summer days.
Posted : 09/05/2012 8:24 pm
