Fox float service k...
[Closed] Fox float service kit
[#8048543]
I'm going to have to service my first forks since replacing elastomers in a set of RC35s *gulp*
I need new seals and oil etc, and upon googling/ebaying, seems to be quite a price range. 2008 120 floats if it makes any difference, but I don't [i]think[/i] it does.
Quite simply, any recommendations from where to buy?
Ta.
Posted : 11/09/2016 5:41 pm
 JAG
I bought a TFTuned kit last January. New seals, oils and lube etc....
Followed one of the many YouTube videos and it was very easy 🙂
Mine are 2008 Fox 32mm 140 travel FLOATS.
Posted : 11/09/2016 8:38 pm
Ta - are they just all the same schizzle then, no matter where you get it from? TF tuned seems expensive!
Posted : 12/09/2016 7:25 am
Do the kits contain the same stuff? Wiper seals and foam rings are probably the same, fox ones normallyncome in their own fox bag from memory.
Posted : 12/09/2016 7:33 am
Cheers Mike.
Posted : 12/09/2016 9:33 am
Ebay for the SKF seals and foam rings, about £20.
Oil, you'll need about 200ml for 2008 floats IIRC, 160ml in the damper leg, 30 in the spring leg. I usually put a little more in there just because.
5ml in the air chamber.
Get some IPA (Iso Propyl Alcohol) and some clean rags for cleaning off stuff.
You'll also need a 28mm(??) flat faced socket to undo the top bits.
There are 3 TINY allan bolts and small ball bearings that hold on the lockout lever, be careful not to lose them!
Posted : 12/09/2016 10:35 am
