fox float rl bushin...
[Closed] fox float rl bushings
[#4871738]
Evening ladies and gentlemen.
I believe I may need some new bushings for my fox float rl. Where is the best place to buy from?
Ash
Posted : 14/02/2013 8:48 pm
If it's a fork you need bushings for, you cannot install them yourself. You need some rather expensive tooling to size them precisely to the stanchions. Get them off to LoCo tuning or TFTuned to be serviced and they will more than likely resize the ones you already have as part of a normal service.
Posted : 14/02/2013 8:56 pm
No its my rear shock. The bushings where it bolts onto the frame.
Posted : 14/02/2013 9:03 pm
BETD strong bush plus hula hoop bushes.
My god my phone predicted what I was going to say. Eeek.
Posted : 14/02/2013 9:37 pm
Ha ha awesome cheers yinn
Posted : 14/02/2013 9:40 pm
Or search ebay for Fox Bush - I just bought 10 off bushes for £8 +p&p. They are 08DU08 bushes if you go to a bearing seller, but the ones on ebay are the same. Get a tool as well as it makes it a 10 minute job, if you use sockets and washers etc it's a 20 minute faff.
I treat them as disposables - that way the shock gets a quick oil change and clean every time I change the bush (which on my Spesh FSR is about every 4 months)
Posted : 14/02/2013 9:54 pm
