I am looking at replacing a Fox RP23 Large Volume can and have seen several options that match the size of 200 x 57, but these have BV LV or BV SV in their description. So which one would be best to replace the RP23?
Posted : 08/12/2016 6:27 pm
BV means boost valve - this is position sensitive damping that means the compression damping ramps up at the end of the stroke.
SV is standard volume, LV is large volume so presumably you would want the LV to replace your previous large volume shock.
Posted : 08/12/2016 6:50 pm
Thanks for reply - LV it is then.
Posted : 08/12/2016 7:08 pm
