Fox Float rear shoc...
[Closed] Fox Float rear shock air leak question.
[#1182459]
I had a problem with air leaking from the valve on my Fox RL shock the other day.
I have replaced it with one out of an innertube which works fine, the question is do i need to buy a new Fox one or are they the same?
It certainly looked the same!
Its an 06 model if that makes a difference
Posted : 04/01/2010 4:11 pm
It's just a standard valve core, job done.
Posted : 04/01/2010 4:12 pm
Top fix there chap, well done! 🙂
Posted : 04/01/2010 4:15 pm
schrickvr6- sort of guessed it would be, thanks
Peterpoddy - Thanks, you have to think quick when your poor 😆
Posted : 04/01/2010 4:29 pm
