I've been a complete biff and sheared the damper rod assy at the base end while tightening up after a seal change. Does anybody know if these are available to buy separately?? I've had a looky at Mojo's site and can't spot them.
Might try some No More Nails epoxy stuff to see if it will bind the remainder to the rod but not hopeful, got a feeling this could be expensive!!
Please help STW, you're our only hope 😥
its about fifty quid iirc you need to call mojo tho as not listed on site
Cheers firestarter, think I could live with £50. Must invest in a torque wrench at some point haha
Did the same WITH a torq wrench on my TALAS begging resulted in the right bit being ordered but the age of the forks mean they'll not be another.
le singe
when you speak to mojo ask if you any of their other forks have the same parts that will fit. you get loads of spare or repair forks on ebay. buy the knackered forks about 20 to 30 quid take the bits you want and simply sell what's left.
not sure if any of these talas parts will fit but I thought id mention it just in case!
Cheers Kaesae but I'm not sure the damper for that TALAS will fit with it being designed for 10mm more travel and a 36mm stanchion. Good idea anyway though 😉
