Fox float F120 fork...
[Closed] Fox float F120 forks - increase travel like Rock Shox?
[#1386181]
Some Rock Shox forks have an "all travel spacer" to increase or decrease the travel.
Do Fox use a similar/same system?
I have F120s and would like 130 or 140mm travel - remove spacer or new forks?
Posted : 05/03/2010 8:18 pm
I believe you can only go down, ie F120 can be converted to 100mm.
Posted : 06/03/2010 9:05 am
 momo
120mm is max travel on F120's. The 140mm Floats can be spaced down, but iirc the stantions on 120's are shorter (and therefore lighter) than those on a Float.
Posted : 06/03/2010 9:47 am
