Hi,
If I suspect that my fox float rear shock has lost some of its damper oil, would it most likely appear from the lower air can sleeve seals or out of the air valve when I attach a shock pump ?
I am not sure if I have this problem. What would the syptoms be if I had lost some damper oil ? would my lockout cease to work ok etc ?
Thanks
Posted : 17/04/2009 1:29 pm
I havent seen any from the bottom seals, just thought th shock pump was a bit oily after checking the pressure
Posted : 18/04/2009 2:26 pm
no idea, but im sure Mojo or TFTuned could help... only a phone call away...
Posted : 18/04/2009 2:31 pm
