Fox Float Boost val...
[Closed] Fox Float Boost valve issues
[#7299119]
Got the 155mm Fox Boost valve fitted on the 2014 spesh enduro... right then, just went to check the air pressure which was low and when I pressed in the (red valve) boost valve quite a bit of oil came out ?? This has now happened twice this morning ?
Its still sitting about 25% but feels way too soft so I take it riding it is not an option ?
Posted : 30/08/2015 9:22 am
That's auto sag (not Boost valve,which is factory set on shocks that have it).The 'oil' is just a bit of float fluid in the air chamber,nothing to worry about.
25% sag is'nt actually that much for a long travel bike.You can put more air in if you want.Try riding it first before you decide you want to run it semi rigid.
Posted : 30/08/2015 10:37 am
Sorry I was meant to say 'Autosag' Thats exactly what I've done now' I've just put more air in and not used the 'autosag' so a stiffer ride it'll be 😉
Thanks for your info bud
Posted : 30/08/2015 10:50 am
