fox float 29 ctd 11...
[Closed] fox float 29 ctd 110mm. Are they easy to service?
[#6219866]
Thinking of servicing my own forks. If it's easy to do I will. Had bike for 14months now and I commute and cannock every now and then. So for piece of mind Ide like to have a look at them.
Would like to replace seals and put new oil in. Where can I get a kit from?
Posted : 26/05/2014 8:00 am
 lump
also interested
Posted : 26/05/2014 8:07 am
 jonk
Seal service is just the same as any other 32 fork - replace the seals, soak the foam rings and fill with the correct level of oil. If you have a FIT fork the damper is harder to service at home due to the tools needed to take it apart.
Posted : 26/05/2014 8:10 am
How much do shops normally charge?
Posted : 26/05/2014 12:54 pm
