Fox Float 150-130mm...
[Closed] Fox Float 150-130mm lowering
[#4788784]
Hi all,
Can you get a lowering kit for Fox Floats 150mm to drop them to 130mm?
If so does it lower the fork height or just stop the fork from travelling more than 130mm?
Posted : 23/01/2013 9:53 pm
it's just a spacer that sits under the air piston to draw the fork into it's travel. you could make one or buy it from mojo
http://www.mojostore.co.uk/acatalog/Travel-Spacers.html
Posted : 23/01/2013 10:18 pm
So does that mean it will sit 20mm lower with the spacer in?
Posted : 23/01/2013 10:20 pm
Yes if you fit a 20mm spacer.
Posted : 24/01/2013 1:33 am
