Just seen these on CRC.
I can’t see a problem but any reason why I can’t run these on my HT?
Posted : 29/03/2019 6:47 am
No reason you can't.
I did order a set from bike discount last year without noticing they were e bike forks, sent them back though as they are a bit heavier than a normal fork - if its the same as the 36 ebike forks (which have 34mm internals) then these may well have the 32mm internals as they are built with a thicker sidewall.
Posted : 29/03/2019 7:05 am
They may have different valving the damper, can’t check now but might be worth checking the spec. However most of the crc seems to be ‘grey’ market so a bit random
Posted : 29/03/2019 8:17 am
Look ok to me. They may make you smile more....
Posted : 29/03/2019 8:24 am
No issues.
They are fine.
Posted : 29/03/2019 9:31 am
