Fox Dyad Rear Shock
[Closed] Fox Dyad Rear Shock
[#5124103]
New bike has this shock but I can't set up the pressure. I need a high pressure shock pump that will prevent loss from the valve when removed. Does such a thing exist?
Due to my weight the positive pressure needs to be 450psi, i.e max. When I release the pump I lose about 60psi. I can not put any more than 450psi so I'm snookered at the moment?
Any ideas?
Posted : 02/05/2013 9:58 pm
450psi???
How much do you weigh?
Posted : 02/05/2013 9:59 pm
According to fox tech....110kgs!!!
Posted : 02/05/2013 10:02 pm
Does the pump really lose pressure when you disconnect it though? I thought that it was just the air inside the pump that makes the psss-noise, and that the loss in air pressure happens when you reconnect the pump.
Posted : 02/05/2013 10:06 pm
Scott did a pump specifically for the old pull shocks they used.They went to 500psi and had a valve at the hose end.
Posted : 02/05/2013 10:10 pm
I lose about 60PSI at that pressure.
110kg in my birthday suit.
First ride didn't go too well with a nice tuck in / low slide over the roots.
Posted : 02/05/2013 10:11 pm
How does that valve work? I need a push on / off to minimise loss when removing.
Screwing it off is too slow at 450psi and loses too much.
Posted : 02/05/2013 10:14 pm
(remembers to be VERY nice to pjm84 in future)
Looks like I need one of these..... Cannondale take note. Thanks
http://www.scott-sports.com/global/en/products/2196840001/shock-pump-scott-pro-black/#.UYLYJd5waAY
Posted : 02/05/2013 10:20 pm
 njm
I used to loose pressure from my shock pump, but since buying one of these I've not had a problem:
http://www.winstanleysbikes.co.uk/product/32095/Topeak_PressureRite_Pump_Valve_Connector?gclid=CJXgp4WG-rYCFe3LtAodB2gASQ
Admittedly I never need to go above about 200psi.
Posted : 03/05/2013 2:33 pm
