fox air shox questi...
[Closed] fox air shox question
[#2426911]
I found myself getting bored this evening so strated stripping down my bike and giving it the once over.
whilst doing this i decided to see what makes the fox air shox (2008 rp2) work anyway. I kinda of sussed out they aren't that hard to sort out
However the question i have is what does the little bleed screw inside on the square bit of the piston thing do as I may of undone it letting whatever pressure was in there out! whoops!
I can't say i have noticed a difference with how the shox preforms so just wondering what i have stuffed up?
Posted : 01/02/2011 8:53 pm
Did it have a white cap over it?
Posted : 01/02/2011 9:00 pm
that one
Posted : 01/02/2011 9:01 pm
someone must know?!?!?
Posted : 02/02/2011 11:59 am
 LoCo
That is the bleed on the oil chamber, if you've let oil out you'll need a re-gas and re-oil.
Which I can sort for you 😀
Posted : 02/02/2011 12:01 pm
Idle thumbs eh 😉
Posted : 02/02/2011 12:42 pm
ah right! I only let a little bit out will it make much difference? 🙂
LoCo can you email me some details and prices etc.
Posted : 02/02/2011 3:38 pm
There is only a little bit in there....
Re-gas time!
Posted : 02/02/2011 4:03 pm
 LoCo
£30 re-oil and gas.
http://locotuning.co.uk/contact.html
Posted : 02/02/2011 4:08 pm
With out that pressure in there (with your damping oil) your damping won't work properly.
As above, get it re-gassed.
Posted : 02/02/2011 4:48 pm
......a little knowledge is a dangerous thing......
Posted : 02/02/2011 4:53 pm
tell me about it! I just seem to have this thing for taking things apart and bodging them back together for no real reason
Posted : 02/02/2011 6:16 pm
