Does any one know if a 2011 spring will work in a 2010 fork?
Posted : 06/07/2016 5:50 pm
The ID of the springs were made slightly larger in 2011, which meant you couldn't use old springs in newer forks as the spring wouldn't slide over the internal stub-shaft-thingee. However, you shouldn't have any problem using a 2011 spring in an older fork.
Posted : 06/07/2016 10:18 pm
ah, cool might be worth a try then 😀
p.s. what do you mean by ID of the spring? if its the internal diameter wouldnt that mean the spring is larger than the old springs?
cheers
Posted : 07/07/2016 10:04 am
ah re read and understand what you mean, the ID (hole in the middle) is bigger on the new springs, so should fit the old models
Posted : 07/07/2016 10:06 am
