Fox 36 Travel adjus...
[Closed] Fox 36 Travel adjustment.
[#583502]
Does anyone know if it is possible to adjust one of the versions of Fox 36s down to 140mm? i see the talas can go from 100-130-160 but is it possible to remove an internal spacer or such from one of the other models like you can do within the Rockshox forks.
Also any news on the 2010 36s? with the 32s now going up to 150mm will we see an increase with the 36s?
Thanks
Posted : 27/05/2009 1:50 pm
Give Mojo a call on 01633 615815.
I'm pretty certain they can lower the travel on Fox Floats for a fee
Posted : 27/05/2009 1:59 pm
float 36's are able to be spaced down in travel.
Posted : 27/05/2009 2:51 pm
140 is possible on float 36's, as is pretty much any other height you want.
Posted : 27/05/2009 3:00 pm
