Fox 36 travel adjus...
[Closed] Fox 36 travel adjust
[#11076927]
As I seem to be unable to sell my radon swoop for some reason, I'm thinking about parting it out and using a few bits off it for my hardtail instead.
I would like to use the forks but they are 170mm and I would ideally like them at 160 googled it and got some conflicting views.
So can I convert FOX 36 170 Float Performance Elite, 3 position, to 160mm ?
Posted : 05/03/2020 9:22 pm
Varies with older ones (2016 and earlier) but I'm.pretty sure you need to swap the air spring for a 160mm one.
Easiest way to be sure us to take the four digit code kff the fork leg, and go on the web chat on the Silverfish site. They'll tell you the exact part, it's about 40 quid. Easy to fit if you're comfortable removing the fork lowers.
Posted : 05/03/2020 9:47 pm
