Fox 36 seal driver ...
[Closed] Fox 36 seal driver alternative
[#5171409]
These are going for 30 something quid from mojo which seems a bit steep. Does anyone know of a bodge alternative
Posted : 19/05/2013 9:07 pm
Pvc pipe cut in half seems to be a popular one, plenty of size options aswell, you can use the old seal upside down, then cut off after the new seal has seated.
Works on motocross front forks so cant see why it wont work on pushbike forks
Posted : 19/05/2013 9:11 pm
Posted : 19/05/2013 9:19 pm
Just done mine. Popped them in the freezer for 30 mins, lubed up the seal and forks then popped them in. I found that pulling inside the seal worked better than pushing the outer edges.
Posted : 19/05/2013 11:07 pm
