I'm totally confident that I'm being a muppet, but quick check....
Fox 34 NA 10cc air spring volume spacers......I've got both yellow and green ones. Both have 10cc volume cast into them. Both look identical in every way. Fitted into the fork no issue and ramps up as expected.
Is there actually a difference between the 10cc green and yellow 34 spacers? (other than the colour)
Use the green if you are fitting 6 or more according to fox to stop rattling, otherwise use yellow up to 5, so must have a slight shape difference.
Now you say it, the green have a tiny bit longer tabs on the sides, they must touch the inside of the stanchion slightly more to prevent the rattling.
Thanks for the info
