Hi , have ordered a transition smuggler 2018 frame, forks that come with the package are boost 34s at 140mm. Should be nice and stiff. However I'm considering using boost 36s at 150mm. Thoughts?
Posted : 11/12/2017 10:55 am
Yes.
HTH.
Posted : 11/12/2017 10:58 am
OIC
Posted : 11/12/2017 11:07 am
Bump 4 da evenin' cru
Posted : 11/12/2017 6:18 pm
What shock are you putting on it?
Posted : 11/12/2017 6:25 pm
Try it, you can always drop the 36's to 140mm later. Theoretically will raise the bb by a few mm and slacken HA but a lot will depend on sag and ride height of the forks.
Posted : 11/12/2017 7:07 pm
I have 140 stages on my smuggler that was designed for 130, though deliberately as they have a shorter a2c than pikes etc. Worth checking the a2c depending how much you want to mess around with the geometry from how it was designed to run.
Posted : 11/12/2017 7:18 pm
