I have this fork, in 150mm guise, on my new Spesh Levo SL. Have only been able to ride it a few times so far and only on tame trails, but it doesn’t get much more than 120mm of its 150mm travel, and pressure is right for sag. I have the correct flat spanners and have taken tokens out of Fox and RS before, but before I do, any idea how many it comes with from the factory ?
I am about 13 stone and a mincer 😀
Found the manual from the ID number, it has 2, so I may take one out, however think I’ll ride it a few more times first and let everything bed in a bit.
Tracey, that’s handy, thanks, good shout on the gauge, will have a look at that.
How you finding the new bike ?
First ride out on it tomorrow, probably up and over Cutgate. Last job was to get the forks and brakes swapped over so I could sell the others on, they went along with the gears straight away. Sorted it in the week so raring to go and compare.
Me and the girls weigh in a bit less so the pressure needs to be near to the minimum setting to get full travel on any fork.
Have fun 😁, look forward to seeing the ride pics !
Well curiosity got the better of me, I opened it up and it had 2 tokens, so I have popped one out and will see how it goes...
Only tokens I get to use are in an Aldi shopping trolley.😉
I’m a token amount heavier than you though 😜
