fox 32 lowers
[Closed] fox 32 lowers
[#2559639]
Hi,
Ive got myself some lowers from a 2009 140 floar r(coil)15mm dropouts which i want to swap with my 2009 qr 140 float rl(air) lowers, is this possible?
Posted : 13/03/2011 11:27 am
You can but as far as I know you will have to run them as coil as they won't seal properly as they've been used with coil already. As when I was checking about converting my Talas to float I enquired about going coil and was told if a convert to coil I could never go back to air because of this. Hope that makes sense
Posted : 13/03/2011 11:31 am
I know that you can change lowers however not sure the coil/air would make any difference or not. You could try emailing Loco Tuning or Mojo Tuning and they'd be able to set you right.
HTH
Posted : 13/03/2011 11:32 am
Cheers, I will send them an email and see if they can give me any info.
Posted : 13/03/2011 12:48 pm
 LoCo
Yes, they're fine same travel and model year, bushes may need adjusting to get really good performance due to possible wear/tolerance differences between the uppers/bushes. 😀
Posted : 14/03/2011 12:08 pm
