Any one know the diameter / spec of the crush washers needed for Fox Float 32s (2009 if it makes any difference).
I assume it's they're a standard size - Mojo want £7.50 for 10!
Bump - anyone know the answer?
Why not measure your current ones ?
Cause then I'd have to take them off and.... not have any new crush washers to replace them with....
all kinds of diagrams and parts lists on the Fox service site
[url= http://service.foxracingshox.com/consumers/index.htm ]http://service.foxracingshox.com/consumers/index.htm[/url]
crush washers are listed as custom fasteners so may not be a standard size
can't you just re-use them?
or they come with the dust wiper kit if you're changing them
I bought these - http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=390131784511&ssPageName=STRK:MEWNX:IT
For 32 Floats.
I did contact the seller first to ensure I got the right ones. YOu could do the same.
Just measured - the internal diameter is 8mm.
Edit- you can re-use them, unless of course, they are [i]crush[/i]ed
What bakes said. Or remove base nut and measure the washer while its still on the stud, outside diameter of the washer and the width of the stud. Or by the seals cheap enough. LoL dez
Thanks people...
